This Forge BOV for me?
If that in fact is a greddy styled flange, then you will have to get either an UICP that is greddy or 1G flanged. If you are still on stock UICP, there are greddy style adaptors out there too.
Is your profile up to date?
yeah all I have is my intake setup. I will buy this BOV if it goes for cheap and get the right UICP which pipe do you suggest I'm thinking about the Dejon Tool UICP..so I'd buy it with the Greddy flange?
Correct. Get the greddy flange with your UICP and you should be all set. You can even go as far as getting a 1G flange if that is an option (obviously get the greddy since it's what you need) since the 1G flange can be adapted to use the greddy flange.
As far as brands of pipes, pipes are pipes. Dejon makes a great set and I'm sure others do as well.
