sp00ln
- 573
- 1
- Dec 27, 2002
Nevada
Eh... Do any of you have a spare 02 to Down Pipe bolt that I could have??
sp00ln said:Unless you were one of the girls who were fighting, or told us our ass was gunna get capped, we didn't meet any chicks. So, if you want, call my cell on saturday and you can meet up.
LMFAO!!! Sounds like the stupid chicks at the racestypical drama down there. Hopefully i'll be able to meet up with you guys, my car is overheating now.
I think its just my coolant level....cause the warning light keeps comming on...easy fix.Stock Josh said:They shouldnt be overheating, thats not a good sign.
It's probably my air temp sensor since the radiator fan doesn't kick in when it should... haven't had much time to look at it.Stock Josh said:They shouldnt be overheating, thats not a good sign.
gobagheera said:It's probably my air temp sensor since the radiator fan doesn't kick in when it should... haven't had much time to look at it.
You're right, the water temp sensor. The AC fan works... both the AC and the radiator fan turns on fine and alternates between high and low speeds depending on the air temperature, but once the AC is turned off, the radiator fan will not turn on no matter how hot the engine gets.Stock Josh said:Do you mean water temp? There is a sensor on the bottom of the radiator that tells the fans to kick on. The A/C fan (the one in front of the turbo) should kick on every time you turn on the A/C, if it isnt, you'll overheat quick from just that.
Thanks for looking out Josh.
