The Purple Monster
Built to take a beating
Hey i was wondering if you had the front tubular k member?
No, I wish I did. I'm not a fab guy so hopefully someone finishes up theirs soon!
Had my new gauges come in. Finally wired everything up and tested them. Seems like my switches, gauges, and relay/fuse box is working good.
Ha..... They are probably one of the best shops in NC so they are packed with stuff. I was told 3 week min. I'm on week 2 now. I haven't even heard pricing or what all needs done yet.
We went over the complete setup and wrote down what I wanted accomplished.
Balanced from balancer to flywheel
Check to see if it needs line honed
Deck head and block
Oring block
Surface flywheel
I think that is all I asked them to do. My setup was one of 5 complete setups they took in that day.
The best place around here typically takes all winter....so I went to another place that is at the top of most people's lists, and he raped me. Damn near tripled his quote. I would have gone to the place I normally send stuff to but he didn't have the tooling for one of the things I needed done.
Hope to see this thing up and running soon!
What do they look like and how much.
You have a roll bar, and not a full cage?
Yeah its just an 8pt mild steel. :shhh: I'm having a cage built and certified after I get it running again.
I'll PM you the info on the rims.
How is that head working out ???
What head? The one I currently use has +1mm valves and casting marks removed from exhaust and intake ports. Nothing crazy.
I had a head that MAD Mike built for me that worked pretty good but I unfortunately melted that one.
Was asking about the Mike did for you. that sucks
Wanted to know how the engbldr valves were holding up for you. I snapped one of the intake valve lastnight on the dyno. Will be going back to BC valves for now.
Wanted to know how the engbulder valves were holding up for you. I snapped one of the intake valve lastnight on the dyno. Will be going back to BC valves for now.
Ah ok. Surprisingly I'm still on the same engbldr valves that were from the head Mike did. They are still kicking strong!
Let me know if you figure out what happened to the valve!
Machine shop finally finished with everything on Friday so I got busy.
Not too bad for 2 days of work.
I need to put some things on order but the main thing keeping me down right now is the oil pan. I had to order a new one and it wont be here until the 9th. Also waiting on the valve cover to get back from being coated.
Should be running shortly after the oil pan shows up!
Wonder whats with the double post LOL ^^^. Build looks great so far bro. :thumb: I can't wait for Vassil to finish the testing on those k-members too. :pray: Did you have those pistons ceramic coated or is the lighting funny in that pic? Sorry if I missed that part of the build. Good luck with the rest of this project!
Yep pistons were coated by Tirado custom coatings.
Thanks!
Very impressive setup. I'm curious have you ever thought about spraying the car?
Thought about it but decided not to yet. It made 800whp before with out it so I figured that was plenty of power already.
Looking forward to seeing the car out again. Maybe this year you can be racing at the Shootout instead of taking video. I'd love to see you come up to WCF with the car this year and handle some of these hondas in the so called street classes. I'm interested how these liberty gears are going to work for you. I take it your on a 300m tcase?
Liberty just modified the stock gears, or do make a gearset for our cars?
