intheb0x
- 0
- Jan 17, 2008
milwaukee,
Wisconsin
have you seen it?
is it a good price?
. Then go and do the next cylinder. I always test each cylinder twice and write both numbers down. When you're done, you need to put anti-sieze on the threads (for his benefit or yours if you buy the car) and torque them back into the head to spec making sure you don't cross the threads. Pick up a packet of anti-sieze when you get the compression tester (little ketchup-like packets of silver-gray goo). I forget the torque spec for the plugs, but you can search for that. It's an aluminum head, so overtorqueing could strip the head. Then refer to the labels you put on the plug wires and pop them back onto the plugs. Arrows are cast into the valve cover telling you the direction the wires should come off the plug wire caps. This helps get the wires routed correctly back in the yellowish plastic wire guides (keeps the wires separated and neatly routed under the spark plug cover). Reinstall the spark plug cover. Put the fuse back into the fuse box and replace the fuse box cover.
/Omg he wants 5k for a 90!?!?! Esp one that has been in several wrecks.
He's in HS, so it's probably been hot rodded and not properly taken care of.
Get a pic up for us!!
i ran to school to take these quick pix.
yeah, the hood is pretty off. Its a carbon fiber hood, and its a little too curved in the center.
The white car next to it is an AMC "Rambler" Marlin. The "Rambler" part to the Marlin is like the WS6 to the Trans Am. A girl in my grade drives it. She's into the whole classic car thing.
low down
91 gst.88k all original.timing belt done at 87k
rebuilt ecu
8 out of 10 on the interior
8 out of 10 on the exterior
evo mani/o2(both ported)
xero mile rebuilt/clipped/ported 14b
3" TBE from dejon
walboro 255
reverse gauges
single pod w/boost gauge
all new shifter bushings
ALL fluids changed
hatch struts are new
K&n
was going to ask 2k obo.sound fair
