The free BCS mod
Evan3493
53
Mar 5, 2010
West Islip, New York
I did the free BCS mod found here on the fourms and i removed the restrictor perfectly =D how do i know if it worked correclty? are there any bad side effects i should no about? thanks
wel i only have 100 dollors onhand atm... can a afford a decnt boost guage with that or no? i only seel them for like 150 plus >.>
Bought my electronic glowshift gauge for like 70 bucks i think
Man you can get a new Autometer Boost Gauge for less than $100.00.
Well here is one used in the DSMTuners Classifieds
Autometer boost gauge
posted by coryf1233
Price: $35.00
City: hanover
State: Pennsylvania
Buyer/Seller Rating: 0
Evan, don't modify your car anymore until you have a reputable aftermarket boost gauge installed properly in your car. Without being able to monitor your true boost level, you could be running way more than your current setup is able to handle.
As soon as you get your aftermarket boost gauge installed, do a boost leak test. Use the VFAQ article to help you, as well as the tech articles on here.
By the way, use rubber vacuum hose for the boost gauge, not the crappy nylon line that most gauges come with.
ok thanks guys i been looking in classifeds didnt no about them intill u guys said so haha >.> so i see people just selling the guage what "hardness" do i need or tubing to actully install one. thx
You dont really need a "harness" for most gauges. just a black wire and a red wire for power to light them up. Then just run the small vacuum line that comes with it from a good boost source on your engine to the gauge and voila.
also i been looking on the fourms how do i actully make a boost leak tester? i cant seem to find a thread or i just fail at useing the fourms
I have to disagree. The white nylon line that comes with 99% of boost gauges out there tends to kink and crack with time. A much better option is to use a brass barbed fitting on the back of the gauge and using a standard length of rubber vacuum hose, just like all the other vacuum lines in the engine bay. It's easier to work with and will likely last longer.
good advice..ive never thought of just running vac hose to the gauge
I agree with you on that, as i have rubber vac lines from my charge pipes to my guage. I dont completely trust the nylon crap. But i do know plenty of people who use it without any problems.
dont waste ## money on a guage like that. save for a little bit and get an aem true boost. you WILL go wrong its electronic but it costs 279.00.. i have an autometer right now and they run for about 60.00 brand new
fixed
279 for a boost gauge :tease: sucker
Autometer is the only thing you need and is affordable.
And if you need help installing...
http://www.vfaq.com/index-main.html
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
