turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
So, in my late night thoughts that often keep me from sleeping i had a rather weird question pop in my head.
Okay, say you're running 43.5 psi fuel pressure but your pump flows more volume at 35 psi. When your fuel pump starts to run low at the 43 psi setting because volume is falling off, along with this pressure drop shouldn't the fuel pump start flowing more volume like it' supposed to since the pressure got lower on it's own?
That's one of the reasons i find it hard to believe that you can make much more benefit by lowering base fuel pressure. Because pressure is going to drop anyway when it starts running out..and according to the charts, lower pressure= more flow (i know this is redundant, but seriously... lets here some thoughts on this) Why will the pump not flow more when the pressure falls off on it's own since it doesn't know wether the pressure is falling off because you set it lower or that the car is consuming more than it can flow at the given pressure....
My assumption is that the pump can maybe push more volume agaisnt' less pressure aslong as the volume isn't being consumed, but all in all it's only going to flow so much either way and when you start running out , that's it you're running out.
