test drove my future eclipse gs-t
vkalloo
98
Aug 28, 2004
Ft Lauderdale, Florida
listen test drove the car...the engine makes a ticking weird sound when the car is in gear at low rpm. once the cluth is disengaged there is no sound. PLease diagnose
It is called crankwalk. Stay as far away from that car as possible. You would be an absolute fool to buy it. When you are pressing the clutch the noise you hear is the crank "tapping" on the crank angle sensor. When you let off the clutch it stops because there is longer the force of the pressure plate forcing the crank to "walk". Find a different car. If you want some more info on it check out DSM.org or Vfaq.com. It is not something you can fix either.
it is 6bolt with about 45k miles on it... could it be.... its sounds like something is rattling around... then when i press the clutch down it goes away
yea didnt mean to hijack.... chances of me get a response on a new thread probably wont happen... unless i offer money... hard to get help now days
here is what is happening. when the car is in neutral no noise. once i put it in gear i hear a weird sound like in third gear doing like 30 mph i hear a loud tick tick tick tick tick like a friggin bug. the cluth is cool everything engages nicely. trannys like new. condition of car is awesome....no flaws one tiny crack like 1 inch in driver seat thats it. nice nice car. even if crankwalk is an issue. i'll jus buy an engine block and replace it with a 7 bolt....how much u think it is....thanks so much
is it that loud thought damn its like a tick tik tick tick and when i put it in neutral while the car is moving is ceases
