Temp Spikes at idle
ModRacerDSM
53
Oct 31, 2011
Hanover, Pennsylvania
When I'm driving my car the fuel temp is normal but when I put it in neutral and let the car idle the temp spikes. Any ideas as to why this is happening? today, just sitting in a lot, the temp went over 2000.
huh :confused: fuel temp :confused: 2000 degrees :confused::confused:
I'm guessing you are talking about coolant temp and meant to type 200. 200 degrees is okay ;)
this is what i get for telling my friend to post this and not doing it myself. Lets try again. my engine temp gauge, not fuel temp i have no idea why he said that? spikes when I idle. i can let it sit and it will go over 200 degrees, not 2000 haha. Usually when im running it it hardly goes above 160. I doubt that theres anything wrong with the sensor. So any ideas on to why my engine temp is spiking while idling? And dont worry hes getting a good smack for being an idiot.
Its simple.... no air flow over the radiator at idle. It will happen on any car, turbo or non-turbo
As long as your cooling system is in good working order, 200* is nothing to get excited about.
Drive the car!
If the fans cycle on and off like they should all is fine.
A cold block, a temp under op temp, will have more wear than an op temp block.
Ok now I understand hahaha! If you run your defrost or heater with your a/c button fully pressed the a/c fan will always stay kicked on. it lowers the temp at idle a bit. really your are all good though man. I have to do that in my Talon during the summer because of hot start issues
