TD06 Compressor O-ring
Sang
Feb 6, 2008
Gainesville, Florida
Tried searching with no results.
Tried calling hahn racecraft 3 times, no one picked up, just kept ringing.
So...Does anyone know the mitsu part number for the o-ring between the td06 20g compressor housing and CHRA?
-Sang
Looking for the o-ring that goes between the compressor cover and CHRA.
I'm pulling my housing on my next RnR to polish the comp, and i'd like to replace the o-ring.
-Sang
You're speaking of the o-ring between the center housing and the compressor cover.
The OEM o-rings are neoprene (black), where yours appears to be silicone (white or orange). The silicone o-rings generally hold their shape much better and will not flatten out like the neoprene rings do.
Pull your o-ring out of the groove and inspect it for flat spots or cuts. If it's in good shape, there's no reason you can't reuse it.
That turbo is actually from a friend of mine from a couple years ago.
My turbo is still on my daily. I'm removing it to timesert a couple stripped threads on the head holding on the exhaust manifold. While I had it off, I thought i'd polish the comp since everything else in my engine bay is polished.
Good to know about the material though. Looks like I can go to lowes (I can take a bus there), and sift through their o-ring selection for the right size.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
