420A Talon Stalling (automatic)
talondsm
Dec 29, 2008
Pittsburgh, Pennsylvania
my talon has been stalling out sometimes when ill be at a stop light or even a stop sign. its an automatic too. my idle will go real low, then my car will just shut off. some people have told me that it is my throttle body. but i'm not entirely sure. anyone know what this might be?
Unfortunately, it could be a number of things. I have the same car, same trans, and same issue at times. It could be your ISC (idle speed controller). What I would do is remove the ISC and clean it. Also, my BISS likes to turn itself. So I have to adjust it every once and a while.
You could have a small vacuum leak some where. My friend's car the other day kept idling really low and then shutting off and he said that he found that a vacuum hose had popped off.
when it is running, what is your idle speed? you may want to increase it a bit as well as check for vacuum/boost leaks
I would think it should be about 500-550 in drive and about 650-750 in park. check for vacuum leaks and try and increase your idle screw
  • Wanted 6 bolt NT water pipe
    • chrisman287
