Take a look at my log please
O.M.G. guys! Open it up in Word then save it as a .CSV then open it up in Excel! Viola!
You need to richen it up some on the low end of things because your low fuel trim is maxed out at 140
If your mods are up to date in your profile then you really don't have a way to tune that out. I would do a boost leak test so you can see if you have a vacuum leak at idle. That will make you run lean at idle and rich at WOT. Do a BLT and get back with us.
