1G Tachometer not working on standalone ECU + different ignition module
Gonza97
8
Mar 7, 2022
General Pico, South America
Greetings group. I´ve installed a standalone ecu, and my tachometer is refusing to work (It did work previously before the change). I also must say that I've replaced the ignition control module to another brand, so it's been a pain to know how to adapt it either to the module or to the standalone. Does someone has an image of the OEM ignition control module where does each pin goes so I can adapt it to the new module? Or where it´s the tachometer one if I want to put it in the standalone? I can´t keep going without knowing which is the one that goes to the tachometer and fry something vital in the process, or having to install an aftermarket tach (Which I wouldn't like to, better keep the OEM going)
