Tach help!!
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
I have a autometer tach that i installed everything but the green wire witch is the signal wire. Were can i hook this wire up??? I heard i can use pin 109 from the ECU. Would this be ok? Its on a 91 gsx
Turboglenn: what do u mean?
I just wanna make sure before i got and start splicing wires!!
Glad you got it working.. On some of the mistus i've built where the factory ECU was eliminated and we didn't want to use one of our digital outs for a tach signal, I found that there's a Tach output pin on the ignitor that fires the coil packs.. Some of them have it and some don't. im starting to get tired, so i can't remember the part # of the one that does have it. But either way, if it's working for you now, there's no need to worry about it :D
EDIT: it's the center pin on the J722T ignitor module.. it just hit me :p
