t3/t4 60-1 boost impression needed in here!
yangtech
268
Sep 19, 2004
Manitowoc, Wisconsin
hey all, was wondering if some of you guys with the 60-1 turbo or any other upgraded turbo can describe to me what it feels like when the turbo kicks in, cause for some reason i dont get the feeling of being kick back to my seat. am i just expecting too much from my 60-1 t3/t4 at 20 psi... maybe its because i'm driving it instead of riding it on the passanger side.?
thanx...
A 60-1 (or equally sized turbo) will kick hard @ 20psi+ levels. Are you running enough fuel/timing? What fuel management are you using?
You should feel your blood pressure rise, as your heart gets squeezed between your sternum and backbone.
i'm not getting that feeling when its screaming at 20 psi... :cry:
thanx...
Let me drive and you get shotgun... :thumb:
Any DSM equipped with a 60-1 turbo with supporting mods and fine tuning will hit hard at 20psi. Tuning is the key to making power.
It should move pretty decent if you get a good use of all that air. Do you have a logger? 19-22 degrees of advance (with the base @5 or more) would start squeezing your heart as was mentioned before :)
