t25 wastegate on 14b
RotaryAE86
249
4
Feb 14, 2006
West Palm Beach, Florida
wondering if its feaseable, found a real good deal on a 14b but the guy says it has no wastegate. i have a couple extra t25's laying around so i was wondering if anyone knew if it would work
I have never tried it but I wonder if it will even bolt on to the 14b compressor housing (i.e. is the mounting plate compatible)? Or if the length of the lever arm is compatible? Just a few things to consider.
There are alot of "dead" 14b's out there. See if you can snag one off of one of them.
i did it on my car. Had to fab up a small plate to mount on the 14b, then drill 2 holes to mount the wastegate actuator to the plate. then tack welded the arm to the wastegate. very cheap -a$$ way of doing it, but i needed a car.. and i didn't have a 14b actuator.. only took like an hour.
