t25 turbo
For the price, I wouldn't bother. Honestly, put a 14b on. It is a way better turbo IMO and combined with a 7cm exhaust housing, youll have a beastly quick spoiling turbo. The larger exhaust turbine housing made a huge difference on the highway.
You can find 14b turbos and install kits for cheap. I got my install kit on ebay.
Ditch that t25. Like ^^ said get a 14b. Since your doing a swap anyway. Dont waste your time installing the t-25.
It looks like that turbo came off of one of those $.99c hotwheels cars. That thing is tiny!
Looks like you picked up a motor from an auto. Make sure you remove the crank spacer.
Yeah the 13g is pretty tiny. Lol auto 1g turbos. You def. don't want to run that one.
Heres an excuse for you to pick up a 14b. You could get a good one for around $100.
You could run any amount of boost you want, how much can you run safely on a stock motor with no other adjustments/modding needed ? Nothing over 16 psi.
