T25 o2 Atmosphere Dump
dizasta72389
30
May 18, 2006
Manchester, New Hampshire
I would like to know if anyone has install an o2 Dump on their t25? Do you people have any pictures? And how easy was the install? :)
the install will about the same on a t-25 as it would on any other dsm flanged turbo.
1. Let the car cool down
2. Use lots of penetrating oil on the bolts and the nut.
3. Allow to sit for 30 minutes at least then break the bolts and nut loose.
4. Break bolts loose for down pipe then remove bolts and nut on O2.
5. Get a new gasket, line up the new O2 housing with dump using the stud and then bolt it all back down.
6. Reinstall the down pipe.
It is time consuming but not difficult.
Sorry i don't have pics to show you but it's really a straight forward install. Watch out for any cops too because it is VERY LOUD.
enjoy!
enjoy!
Yep thats pretty much it.....and also like stated its not somuch the turbo but the O2 housing. Were you looking at buying one or going custom? Here a link to our custom one.
http://www.dsmtuners.com/forums/showthread.php?t=154808&highlight=home+made+02+dumps
I know, I dont have the time or expirence to do custom but I found the ebay ones for like 90 dollars, I was juust wondering house easy the install would be on a stock t25. Thanks :)
FOr the most part its easy. You have the directions listed above...go get em
Bringing a thread back from the dead, just curious to know what gains you can get with an o2 dump on a stock t-25?
I am sure you wont gain much, but eliminate a lot of boost creep. Because the stock o2 housing is so small, the oxygen builds up causing boost preasure to rise, an o2 dump, dumps the oxygen thus eliminating the boost creep.
  • Wanted 6 bolt NT water pipe
    • chrisman287
