manifold atmosphere dump
cory51191
200
Aug 10, 2008
Leominster, Massachusetts
Not sure if this matters but if the setup was a Frankenstein 6-bolt, CX Racing exhaust manifold with 38mm wastegate flange, 3" turbo-back exhaust, "stage 3" porting on the head and the Frankenstein 274 camshafts...
What would I need to do to safely dump this to the atmosphere (38mm TiAL wastegate on an aftermarket exhaust manifold)?
I dont see why you cant run a stock exhaust manifold and port it or get it ported. there is a lot of flow to be gained from a stock one.
I don't like the way it looks compared to an aftermarket with a nice chrome polish.
Makes the bay look so much cleaner so I'd be willing to spend that extra money.
And its just such a convenient exhaust manifold. Fits both T3 and T4 patterns and has the option of an external wastegate. If you don't want to use that feature then put a solid flange on it. http://www.thedsmgraveyard.com/product_p/cxrmf-4g63-t3t4.htm. You could use this one manifold to run different turbo setups, I didn't know they actually made any like this until just recently.
pj91gsx is right, best to go with a recirculation o2 housing. It's not like you need it for your turbo and having a dump tube will not pass smog either. Just wait till you upgrade to a bigger t3/t4 turbo to do a dump tube.
So I should cover that wastegate flange with one of these (http://www.thedsmgraveyard.com/product_p/mv14290.htm) until I upgrade my turbo? I'm assuming it would create turbulance but would it be safer?
I'd rather hear a 3" turbo-back over a dumb tube though I don't really like the way it sounds IMO.
But I'm talking about having an atmosphere wastegate on the exhaust manifold and haveing the O2 recirculated.
I'm really confuse here. Do you actually have a the manifold with a wastegate flange or not? The link you posted is a t3/t4 manifold with a wastegate flange and you don't have a t3/t4 turbo and what I would suggest is staying with a normal Mitsubishi manifold and have a recirculation o2 housing like this:
I'm really confuse here. Do you actually have a the manifold with a wastegate flange or not? The link you posted is a t3/t4 manifold with a wastegate flange and you don't have a t3/t4 turbo.
No not yet, I'm ordering a bunch of stuff when I come back from basic. I can't really find any info on a manifold wastegate spit out to the atmosphere, so I'm trying to learn about it before I order anything I don't know about.
I'm really lost here as well, are you buying this for the performance or for the looks and sound?? Just use an externally gated o2 housing and buy a chrome heat shield for your 2g manifold since you like shiny stuff.
