t-case leaks, but only when on a angle
xcelr8n
1,854
5
Jan 31, 2003
toronto,
hey guys, i got a annoying problem.
today i noticed there was a puddle of gear oil under my car when i went out to leave.
I immediately gave it the sniff test, because i just fixed a oil leak, wanted to make sure. its definitely gear oil, and im pretty sure its coming from the end of the case, where it meets with u-joint of the driveshaft.
the gear oil is splattered around my exhaust and underbody as well.?
the weird thing is, i park on a angle at my house, about 10 degrees, and it leaked to the ground, but when I went to work tonight, parked for 8 hours, on a flat surface, there wasnt a single trace of oil to be found.
any ideas on this ??
oh ya, by angle i mean the car is higher in the front than the back.
thanks alot
Check the seal in the back if the t-case where the drive shaft goes into the tcase.. if its that just buy a new one and put it in.. That happened in my car because one of my carrier bearings went bad and caused the driveshaft to have play and broke through the seal.
Yes the seal. Also because it is only leaking on an incline i would assume the fluid level is low. Also this may be the tcase recall yoke.
If the recall hasn't been done take it to the dealer.
yes, im sure it would be covered under the recall, as i am now pretty sure it is the yoke.
BUT my car has already had the recall done, does that matter, or is a one time fix, and now im screwed.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
