Synthetic Oil [merged]
DrunkenMime249
Jul 16, 2002
Henrdon,
All synthetic oil threads are merged here.i'm trying to buy a 1g dsm turbo awd (as i'm sure most of you know by now from my recent ramblings in other threads). Most of the ones i've been looking at are bone stock for the most part except repairs and i have a feeling all are running on regular oil.
my question is when i finally buy one should i run regular, full sythetic, or somwhere in between (i am planning on running full synthetic).
also, if the car is running regular and i want to switch to full synthetic, i've heard it can be damaging to switch all at once. or is that just a fable? it makes sense and i was planning on slowly uprading the oil quality everytime i changed it until it was running full synthetic. is that the wrong thing to do?
That's the reason most run regular 30w for break in, it's cheap and you won't feel bad for tossing it in a few miles. But I do believe there is some truth to conventional being better for breaking in engines. It's less "slippery" than synthetic so it, in theory, should help the rings seat by allowing more friction. I don't think synthetic will stop break in, but it sure wont make it easier or cheaper.
Also, break-in oil (or at least some break-in additive) is good to use full time due to it's high levels of ZDDP. Bearings (especially journal bearings) can't get enough ZDDP in their diet. That's one reason why oils like Rotella and Brad Penn are so highly regarded: High levels of ZDDP.
nicely said :thumb:
Motor Oil 101 - Bob is the Oil Guy
Member gprix1 posted this a few hours ago in the "ofh prted 100psi" thread. Credit to him for bringing it to my attention again. Here ya go wes and anyone else who has 30 mins to spend.
Now also keep in mind that racing and DD are vastly different things. Racing is near constant heavy load, high rpm use. Racing is NOT a 3rd gear pull every now and then, ok? I think that needs to be clarified. After reading this i have completely decided against 15/40 for MY application. A 5w40 synth will be perfect, especially due to the cold temps in the winter where i live. A 5w30 might be even better but i like my oil pressure at warm idle just as it is. Going to a 30 would lower it obviously
^^ Yea, rotella(either t5 or t6) has around 1300ppm zinc content. Its a very good oil. However im personally switching to t6 5w40 after reading bobistheoilguy(or whatever its called). There is absolutely no reason to run a cold engine with 15w40. Its senseless. Those 10 pages should be read by every member on here. It would put an END to oil debate. It also tells WHY synth is better and HOW it is better.
Please excuse my ignorance, but what, why, and how does Zinc help the oil/lubrication of the engine?
I understand Zinc is used to coat our drilled/slotted rotors, in order to prevent corrosion. The zinc reacts to corrosion providing a protective barrier against the rust of carbon based steel and iron.
FP is saying that "race temp" for oil is considered 200F??? Im i missing something cause almost every car runs at over 200F which means the oil is around the same. Race conditions IMO, would be more along the lines of 300F and up.
copied from the link: Race engines that operate with oil temps above 200F should
run 20w-50 weight racing oil.
I think the key word here is "race engines". Under "racing" conditions. Racing being alot of high load, high throttle and minimal cooling time. The guy with a 600whp street dsm that does an occasional 1st through 3rd pull is not under "race conditions" thus i dont believe 20w50 is at all necessary. Its only good at causing excess wear on start up due to the thick ass oil.
After reading the link i posted i think most would agree. Maybe BOB is full of shit LOL, doesnt seem like it at all though. Take from it what you will but it has changed my views.
Oh and i believe page 7 of that article has something to say about ZDDP levels and how too much can actually be BAD.
It is necessary to keep the oil pump happy at high RPM. I have tested it and seen for myself if its a summer drag car or even street car with any mods over 350 hp in a 4 cyl a heavy oil is best. Now if its an all season car that sees 20* cold starts then yea use a 5/40 syn. Thin oils are for MPG and super cold starts. Ask any big dsm racer what he uses.. Its kind of funny they all use basicly the samething. Also to add ZDDP is an extreme pressure additive it is a great additive but it will eat up catalatic converters for that sake it is bad but for a racer we want as much as we can get.
So let me get this right: Youre saying that the heavier oil eg. 15/40 would be better than 5/40 in a high horsepower application? I know this is what i have been told over and over too but for no real reason. If they are all both the same at operating temp then why do i need thicker oil at start up?
Im not patronizing you at all. I just stumbled upon this article thanks to another member and felt enlightened after reading it(LOL). But please explain. Is a 15/40 thicker at OPERATING temps than a 5/40? That is the ultimate question.
Hopefully nobody here uses mobile1 extended... Claims that protection is guaranteed up to 15k... I can't think of any oil filter that protects up to that mileage... Scary... Synthetic Oil | Mobil 1™ Extended Performance
I once used it on my old car when I couldn't find regular mobile1 but changed it out after ~5k
Amsoil Signature series engine oils offers up to 25K miles or once a year oil changes, more details here:
AMSOIL SAE 10W-30 Signature Series 100% Synthetic Motor Oil
Of course that would not appy for our turbo engines, but for a daily driver with high efficiency amsoil oil and air filters, the draining interval could be extended up to 15K miles or once a year. Assuming engine is in a healthy state and does not run on E85.
I use Amsoil dominator 15W50 engine oil and change it twice a year regardless of mileage because I run E85 gas.
AMSOIL DOMINATOR® 15W-50 Racing Oil
You need thinner oil at start up. 15w40 means that the oil flows like a 15 weight at cold conditions, then at full operating temperature it flows like a 40 weight. For most cars on this site running a 20w50 makes no sense as its just causing high oil prrssurre, improper flow at cold start up and and bad mpg. For those that say you need thicker oil due to different tolerances and high rpm, that's fine but if you drive the car on the streets and have to do cold start ups you still need to consider the "winter" grade that you run.
To say all oils with _w40 are the same weight at operating is correct in a sense but keep in mind each have different additives in them and in some cases those additives are used to increase or decrease the oils advertised weight.
^^^^ exactly my point. I know that ALL 40w(or 20,30,50W) are not exactly the same at op temps, obviously. But i would like to hear from someone who can tell me why anyone would want thick oil on start up. Even on a high horsepower application. I cant seem to understand it and the data seems to support my thoughts. Ive been running 15 40 rotella for 2k miles because its very popular on the forums, and im switching to t6 5 40. Im doing the switch tomorrow or friday. Ill post back if i notice a difference in cold idle pressure and hot idle pressure. It should be lower on cold starts(BUUUUT, actually that will increase the lubrication). We shall see
97 Eclipse 420a. Didn't leak a single drop of oil, ever. Switched to Valvoline Full Synthetic 10W-30 and now I have the worst leak ever. #### Synthetic.
I usually go with K&N gold, I think you just need to give it a bit more hand strength honestly. The K&N also has a hole pre drilled so you can safety wire it if you're worried about it coming off.
