swapping motor 420a
farmboy108
Jun 17, 2006
dover, New York
I just bought a 1999 rs and am putting a new motor in it. I am fairly mechanically inclined but figured i should get a complete repair maunal to help me with wiring everything correctly. I want to know a good manual that would show me everything to know about this car. I would appreiciate it if you could give me a link or name brand. thanks
Or the factory service manual (FSM) and technical information guide. You can pick up copies are your local dealership, or download versions floating around online.
It shouldn't be too hard to pull the engine and put a new one in. Just make sure to label all harnesses and vacuum lines so you remember where they went to before you disconnect them all.
I would get this one. It's awesome! $150 it shows 420a as well as 4G63..
I am happy with the haynes manual and if there was anything else i needed to know i'd call the local dodge dealership and usaully a mechanic would be willing to give some advice.
95tsi New long blocks from the dealership are 1800CDN.
Check out local salvage yards for engines. Most of the time they have some and for a good price depending on your area.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
