Swapping 97 engine into 95 GSX
Eeeeky
344
4
Oct 8, 2008
Roosevelt, Utah
Hey guys, recently got a 95 shell, to put my rebuilt 97 engine in after the crash. Its all in, and recently did the rewiring of the CAS (red-red, black-black, blue-blue), and still have no spark. Naturally, the engine just cranks like theres not a problem, but there is for sure, no spark. Brand new wires, NGK plugs, this engine ran in the other car, two weeks ago.
Should the wires on the CAS be matched? I also tried swapping the plug wires from 1432, to 3241, and nothing there either. No spark regardless, i have the plugs out, and touching ground to watch for spark. Tried two CAS's as well, what might i have missed?
Also just found to have no power at the fuel pump, thus no fuel flow. There is power at the fuel pump relay when the key is on the start position, but no power to the pump connector. Please help!
Hey guys, got an update. I was able to get spark by jumping the red wire on the the Crank sensor to the positive terminal on the battery. I am still at a loss as to why there is no power at the fuel pump, there is power at the relay, when the key is on the start position, but not at the pump. i havnt done the mpi repay, which is next, but this is annoying.
