Swapped a 2.4l block with 2.0 head in 99 eclipse gs
Ryan Fultz
Apr 16, 2015
portsmouth, Virginia
But now I want to add the underdrive pulley, I don't know if the UDP would be the same or where to buy a quality one? Anyone have any tips?
You do not want to do that...
Unless beat out mains is what you want.
The Fluid dampr would be the way if you want to upgrade.
The factory damper absorbs some of the harmonics of the crank, the solid underdrive will not.
Search around and you will find out about the fail that comes with the use of one.
Nice! Got a question tho for you what year block and head combo did you do been looking into this build a little just curious is all
