DeNoZZo
- 685
- 1
- Jul 6, 2008
Waterloo,
Iowa
Well, I the talon just got back from the shop, and it doesn't look good. I was going to get the timing adjusted and the entire vehicle inspected, but they didn't know how to adjust the timing on my car.
Heres what they say should be fixed-
Flush brake system W/ABS- 17.99
Brake system flush labor- 50
Tie Rod Ends (upper-front right)
Tie Rod Outer- 58.99
Labor- 72.00
Ball Joints
Upper ball joint- 87.88
Remove and replace F ball joint, upper 72.00
Braking system
Remove and replace wheel speed abs sensor rear 146.94
Labor- 72.00
Shocks (rear both)
R Ultra strut 2- 157.39
R strut mount 2- 63.38
Inspect and remove rear shock and strut assembly-144
Alignment Service- 69.99
Fuzion Tires 4- 495.88
How should my priority list look? I don't have the money to get it all done right away.
Are there any parts that should be upgraded instead of using oem parts?
What can I change myself? (why even ask.... right)
Labor- 72.00
Ball Joints
Braking system
Labor- 72.00
Shocks (rear both)
