Suspension differences
RaceDSM3
Nov 20, 2012
Phoenix, Arizona
I jus bought a gsx that is missing lower and upper control arms as well as struts and other misc suspension parts. Now what I'm wondering is can I put suspension parts from a n/a on the gsx? I got a rs with a blown motor and was wondering if I can use it for parts for the gsx? In need of knowledge
In the front, most suspension components are the same. In the rear, some are the same but most aren't.
The bolt pattern where the hubs attach to the knuckles (spindles) are different so you can't use AWD hubs in a FWD knuckle and of course you can't use a FWD hub with an AWD axle 'cause there's no splined bore in the centre to accept the axle.
The upper and lower control arms are the same and so is the trailing arm.
Toe control arms are slightly different.
Sway bar end links are the same.
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
