2G Suspension Bolt/nut sizes.
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
Hey, so im putting the motor in tomorrow and wondering if anyone knows of EVERY bolt and nut size ...
i need to know because my buddy took the suspension off and doesnt know where bolts went...
please and thanks!
Well i bought 2 m10x75 with the washer, one of them 1.50 pitch the other 1.25 and the 1.25 started but stopped the 1.50 was tight but when wiggling while threading it seemed to thead it 4 or 5 turns with my fingers as to not force anything so my guess is 1.50...but havent hit anything with a wrench yet as i dont want to create a bigger issue but ill try the 1.25 again in a.m always hard figuring out what previous owners did sometimes. Car was missing bolts and had a 6bolt swap with alot of electrical tape and chewing gum haha so trying to get everything as 100% as possible before atempting to drive it other than around the block
Not sure if this will help any of the 1G owners. I pulled my entire front and rear subframe. Started going through these diagrams to get part numbers and replace all of my hardware. Since the thread pitch isn't listed I've been testing every bolt individually that I pulled off. I haven't found any bolts that weren't the 1.25 pitch so far. Not saying that's a fact for everything, but seems to be the general pattern.
Due to popular demand, I present 1g AWD:
Id hate to start a new thread, so I hope replying to this will work, but do you have that first two diagrams for a 97 GSX? I’m trying to figure out the bolt lengths for the front cross member braces !
40279C - M12x92.5 bolt
40286F - M12 nut
40299D - M12 lockwasher
40279B - M12x50 bolt
40299C - M12 "special" lockwasher
40286B - M10 flanged nut
40694 - M10 nut, washer assembled
40395B - M12 nut, self lock, flanged
40395C - M10 nut, self lock
32166F - M10x22 bolt, washer assembled
32166B - M12x90 bolt, flanged
32166C - M10x75 bolt, washer assembled
32166D - M10x45 bolt, washer assembled
40387B - M12 nut
40381 - M12 lockwasher
40388B - M12x135 bolt
40388D - M12x35 bolt
40387C - locknut
40388C - M12x60 bolt
For a 1997 Eagle Talon ESi what is the bolt and nuts thread and pitch for 40279C (bolt) and 40286F (Nut) i ended up losing my driver side and gonna replace it.
If you’re replacing both the bolt and nut, the pitch doesn’t matter so long as the replacements match each other. The original was 1.25mm pitch.
