aaronmatusz
- 118
- 2
- May 24, 2005
new london,
Wisconsin
First, I'll go over my goals for my car:
I'd like to be able to pound the crap out of my car for fifteen minutes strait without worrying about things overheating, blowing up or whatever and still squeeze out around 250whp.
I just put on the FMIC, Fluidyne rad, 550cc injectors, and SAFCII (see the full list below) and I now can boil off most of the coolant by putting the AC on...this is not the direction I wanted to take
Suspension:
My car was hit in the rear when I got it and I think the chassis is twisted a little. In the front, the camber is positive on one side and negative on the other, also I get the impression that most of the weight is sitting on the right/front and left/rear tires...what can I do about that? Sounds like coilovers would compensate...
Speed Mods
Small 16G turbo EVO 3 manifold 2.5" turbo back 190 lph pump PCV catch can K&N stock replacement filter VDO boost gauge Dejon 2.25" upper IC hard pipe Dejon MAF to turbo hard pipe hacked 1G MAF Fidanza aluminum flywheel CFDF clutch Greddy ETG 550cc injectors SAFC2 VRS 2.5" turbo back Stainless braided brake lines fluidyne radiator DSMotorsport Street FMIC kit EPROM ECU with stage III chip from dsmchips.com All of the "free" tricks have been done to the intake.
Engine Internals
New lifters, oil pump housing and balance shaft eliminator kit.
Suspension Mods
AGX shocks 1 inch lowering springs F/R sway bars Hawk brake pads '93 big front brake kit rear trailing arms with active toe eliminator kit
Suspension:
Speed Mods
Engine Internals
Suspension Mods
