Super quick question about SAFC!
my98GST
1,045
21
Jun 1, 2005
Cleveland, Tennessee
I was just curious as to if the wiring harness on SAFC's are univ. I have a buddy selling his for a hundred bucks and he said he'd give me his for 75 (perfect working condition) So i figured I would find out and buy his if it would work before I buy this other guys for $200
Yes, they are universal - you'll need to hard wire it in to your ECU harness by hand using the ECU pinout and wire color code.
The harness is pretty much there to extend the wires. Without the harness, you'll be fine. I wired mine up to my ECU just fine without it. Just be careful when wiring it. Just keep in mind, this is your ECU. The brown and black wires I believe are grounds. They have to be about 1 cm apart and one has to be closer to the ecu than the other (i think brown?) Then there is your power, TPS, o2 sensor... i think its a total of 5.
-PAUL
