Suggestions on build
stroked4G63
Apr 27, 2005
San Diego, California
Ok gentelmen, my bearings well one rod and one main are eaten up. So I am going to do a rebuild (again) The motor is a 7bolt but currently has a stroker set up. I took the crank out and i had it polished...and is perfectly fine. it looks as though there wasnt enough oil getting down there. Any suggestions on how to make sure this doesnt happen again. I ported the oil relief port on the oil housing but i dont want to let the bearing wear occur this soon again (12k). I think my big mistake was running with high oil pressure and using federal mogul bearings (alluminum) so i am thinking if i go with acl trimetals and maybe plug the oil squirters then i should be fine. Any suggestions? Also i will be doccumenting the build for the forum!
:thumb:
I don't believe in aluminum bearings but you must have a pluged up oil gallery, or last time it was assembled there was some gunk in the oil hole. If you have fordged pistons then block off the squirters.
Yeah i spoke with the guy from overbore. I told him that my block was lin bored, each cyl was bored for each piston, rings gapped indivdually and the entire assy. was balanced. He asked if it cw and i replied no...it was within spec. I told him my crank was no marks and he basically replied with well the only thing i would do is have u ship the crank and he would nitride it and use his modified tri metal acl bearings. He claims he uses a thrust bearing from an entirely different car. As far as plugging the oil squirters i just might do that...I should have mentioned that i think the fron cover gasket blew and all the oil shot out. Hence me porting the oil relief. Well i am greatful for your advice, please keep it comming. Oh and my parts were machined by a shop here in san diego, my buddy who races the 5.0 302 blocks has been going to this guy for all his work. they did an excellent job, cost me an arm and a leg since shamu doesnt pay much (i work at sea world san diego). Thanks again...:thumb:
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
