suggestions on a 4g63 n/a build up
eclipsekid1013
162
May 9, 2010
hudson, New York
alright i decided to do a 4g63 na build up i have a 92 with 140k with 5 speed trans im going to tear it down i have the head block intake mani all that stuff as far as internals crank cams pistons rings rods valves go what do yuo guys suggest. i was told look for a full rebuild forged kit i was told eforged pistons and rods are the way to go. does anyone have any suggestions on companies or websites with full rebuild kits and so on and so fourth. i also want to build it up so should i do diffrent cams and so on and would that heavily effect my injectors and my fuel rail
If your gonna rebuild a 4g63 might as well go turbo.
But, if you want to build a N/A motor. Go High Comp- 10.5:1 - 11:1. Port and polish head. Bore .040 over. 1mm oversized valves. Cold air intake. 100lb shot of Nitrous.
Can you run compression that high on a Non Turbo 4G63 2.0 liter? Also where would you suggest to get the oversized valves for the DOHC 16 Valve? I am also doing a rebuild on a 2.0 Liter NOn Turbo 92 eclipse. I know mine is a 6 bolt but later years are a 7 bolt.
