brute
- 1,551
- 47
- Jun 29, 2005
Rio Rancho,
New Mexico
I'll start from the beginning. My car didn't do this up until a couple days ago. It just so happens that I just installed some new things. Therefore, I'm thinking that something I changed has made the problem.
Problem:
Car drives fine, but feels a tad slow. It takes forever for boost to come on. And when it does, the car studders and stumbles all over itself.
Things I installed that may have caused the problem:
-new o2 sensor
-MAF translator
-injector to head o-rings
-Dejon "no pre-turbo MAS" intake
Things I've done since the problem started:
-boost leak test
-check wires/spark plug well boots
-check plugs themselves
-check plug gap (NGK BPR7ES set at .30")
-boost is set at ~11psi
-fuel pressure is at 37 with vacuum detached (about 30.5 attached)
Here's some pictures of the spark plugs. I can't diagnose anything just looking at them, but if you can, let me know. From the left to the right, it's cylinder 4, 3, 2, 1. As if you were looking from the front of the car.
I've just run out of ideas. Any input is welcome.
Problem:
-new o2 sensor
-MAF translator
-boost leak test
