car stuttering help
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
When I let off of the throttle while accelerating hard my car stutters and shakes violently back and forth suddenly and stops. I believe it happened after I moved my greddy electronic boost controler remote that is in the engine bay. I mounted it to the head and chaged the 6mm tube to a 4mm which I had to raise the % on the boost controler. Does this have anything to do which the stuttering or any other ideas and ways to fix this? Sorry if that doesn't make to much sense.
avaien said:
I mounted it to the head.
-Mount to the head? you're suppost to use the least amount of hose and stay as far away from heat as possible. I mount my on the firewall with a heat shield covering it.
Isn't that pretty far from the wastegate? Also what do you do with the stock boost control solenoid? Unplug it or just let it flow?
-I cap off the nibbles on the waste gate solenoid, I was going to mount it by the air filter, but there is too much exposure to the element there because of the way I sit my air filter, so I mount the boost solenoil to the right of the fuel filter.
