Stupid Coolant temp sensor issue...
atruepretense
166
Jul 15, 2009
Bethlehem, Pennsylvania
So i'm getting the really fun, but wallet draining P0125 code. I know for sure it's my coolant temp sensor, because the O2s aren't failing and are reading correctly. I haven't replaced the thermostat, but the car isn't overheating.
I went to autozone and advance auto parts to get a Coolant temp sensor, and then both gave me a sensor that has a different plug! The sensor threads in correctly but I cant plug in the harness???
The harness on my car is black with a greenish looking inner connector. My stock sensor plugs in perfectly. The sensors I keep buying are similar, but the actual inner connector is more rounded.
I'm thinking of just splicing it in, but I don't want to go ricer style on the car and start hacking harnesses. It's just that getting 70 miles to 7 gallons is annoying as ####!
Anyone know what the hell is going on? Thanks!
UPDATE:
I finally found a coolant temp sensor that would fit and that is exactly the same as the one that was on the car. After careful searching, I found that the sensors the auto parts were trying to get me were wrong.
I changed the sensor, drove the car, and the check engine light came on again. Same code, P0125. Insufficient Coolant Temp. What's the next thing I should try and check? i'm thinking thermostat maybe? Or possibly o2? My idle stabilized quite a bit and I feel like I get a bit better gas mileages but it can be a placebo effect. the MPGs are still garbage.
I ended up having to splice mine before... I wouldn't recommended it unless you need to the connectors always came out and my car would randomly star sucking up gas again. Maybe try using a 6bolt sensor. You could probably look at one and see if thats the connector you need.
Why don't you just take your stock sensor with you and match it up? I don't mean to sound like a dick I'm just saying don't splice the wires just get the right sensor.
Nah no prob bro. I wouldn't even think of touching my harness until the last resort. I'm just lost because the sensor that 3 stores have told me is the coolant temp sensor doesn't match my plug. So I'm wondering how it could happen?
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
