Stuck at 350 whp
trickirickey
Aug 28, 2005
twin lakes, Wisconsin
Hey i was wondering what would be the next step in tuning up my ride i have a 99 gst 350whp
hks cams
650 cc injectors
exhaust intake ex. ex.
but don't have any intoners
fuel pump
agp L2R turbo 50 trim
wires spark pg
fuel rail supra tt
and basic mods
which should i go for
as in pistons crank shaft in such
and what kinds?
Well one thing you can leave alone is the crankshaft, it is good for WAY over 350hp. You'll need some sort of tuning device(logger & S-afc or DSMLink, etc.), and also gauges (EGT,Boost,etc.). There are many threads about this where you will find more answers by searching, also check the Tech Guide as it's got tons of info.
Sorry about my spelling im at school so i need to type fast. and i ran it on race gas at 22 psi and normal at 18psi at 93 :dsm:
4g63t said:
With 48+ knock and timing being pulled.
Uh...or not. If your current tuner can't tune you to 22psi on a 50 trim and 93 octane then you need to go somewhere else.
Trickirickey: What kind of tuning do you have done at the moment? I'm guessing you have a fmic because of your current power levle, but if you don't that is deffinately a must. Seeing that you are on a stock motor I highly recomend throwing in some arp headstuds. If you do them one at a time in the correct order then you won't even have to take off your head or worry about expanding your headgasket and having to deal with that whole mess. With some arps holding the head down, you should be good to turn the boost up c few more pounds on pump and make some more power. For what its worth I just made 402 to the wheels on 91 octane on my 50 trim.
gr8popp said:
can you teach me how to use DSMLINK without a laptop please??
Dude what is your deal with the multi post of this??? If you are being serious then you can't use dsmlink without a laptop. If you are trying to be an ass get the hell out of this thread because shit like this isn't needed when someone just needs help.
I did not see an upgraded side mount or front mount IC. That should show some gain in power. Get that DSM link on there and have fun. Limited slip woould help also if available for n/t tranny?
which hks cams?
also, what are you using to controll those injectors?
What size exhaust do you have?
what kind of fuel pump?
how much boost?
FMIC?
stock mas?
stock intercooler pipes?
you can also tune your cams to get the most out of them with adjustable cam gears
    • Sdcryan1
