stroker kit rod question
tim4g63fast
225
5
Mar 1, 2004
grants pass, Oregon
Okay havent quite been able to search out my answer but my computer does not want to search either at work so i have been working from my phone.
I have the rods from a 2.3 stroker kit intended for the 2.4 cranks in a 4g63 block, I believe these rods to be the 150mm rods correct? which is the same as stock correct? which means I can use them in the 2.0 6bolt build im doing at the moment correct? LOL
Just wanted to double check before I go assembling something that wont work.
thanks guys
You didn't say if the rods you have are for a 6 bolt stroker kit.
Rods for the six bolt 2.3L stroker are the same as for the six bolt 2.4L and the six bolt 2.0L.
Same for the 7 bolt versions.
Rods for 6 bolt versions are different from rods for 7 bolt versions.
You didn’t say if the rods you have are for a 6 bolt stroker kit.
yeah the rods came in the kit witha 6bolt 4g64 crank.
so it sounds like I was right the rods out of my 6bolt stroker kit will work in my 6bolt 2.0
sweet.
thanks
