Stroker Question
djmixerx
325
Oct 16, 2002
SF BaY Area!, California
i need to know what is the part number for the 6 bolt 4g64 crank? or is the g64b crank the same? could u use the g64b crank with a 4g63 block. is it the same as the 4g64?
Also need the part # for the clevite bearings or the mitsu one or both.
g64b is for 6 bolt.
4g64 is for 7 bolt.
yes, you can use g64b crank in a 4g63, as long as its a 6bolt. No, it is not the same as the 4g64 crank, because the 4g64 crank is for a 7bolt.
Got it? Good. Any more questions like this, just type "stroker" in the search function and you will find everything you could possibly need to know about a stroker motor, including your part #'s.
Good Luck.
I just went through the same thing. I am going to go with a stroker myself and the prices for the stroker kits where too high for me to pay off at one time so i went ahead and got all the parts (crank, pistons, and rods) seperate and saved a bunch of money. If you want the crank for a 1g motor (6bolt) you can get them for a good price at www.slowboyracing.com they have them new and used. Either one is cheaper than you can find them at any other place including ebay (as far as i know at least) and yes that 6 bolt crank will be made by hyundai and not mitsu.
