stripped the oil feed restrictor fitting!!!!
johnmarines
377
3
Jun 1, 2008
houston, Texas
I need to find where to buy a oil feed restrictor for my presion 6252 ballbearing T3turbo. I seemed to have stripped it out OMG ! Its the fitting that that screws into the turbo and i can screw my oil feed line to. A link or part number to what I exactly need would be great.
-4 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
There's one piece that could work for you. It depends on what size line you are running and how it's set up if it will work for you though. Also don't hold me to that size, it may not be correct for that turbo and or your setup.
This looks exactly like the fitting that I have. I'm worried that the fitting will not fit into the turbo itself. Are all these universal that will fit my precision t3 6252 turbo?
No they are not all universal. Is this a 6262 ball bearing? If so I do believe that will use a 1/8 NPT thread and that Garrett fitting I listed will be a 7/16 thread.
I have a 6252 ball bearing turbo... Not sure if they use the same fitting.
Ok being it's the ball bearing version it should use the same 7/16 fitting that I first linked you to. Even with seeing and writing ball bearing several times I had their journal bearing turbos stuck in my head.
You can also get it here in silver for just a little more.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Garrett Dual Ball Bearing Oil Restrictor Fitting
THANKS!!! Just what I needed to know. I just ordered it through extreempsi.
