stripped blance shaft bolt hole
Drill it out and heli-coil it or replace the front cover. Or eliminate the balance shafts and jb weld the bolt into the hole. Not much else in the way of options.
If you have already eliminated the balance shafts then just jb weld the bolt in there and forget about it.
