Street Tuned Motorsports Radiator Brackets
I finally got this in the mail today and looked it over. It's a simple radiator bracket. There's no secrets, no performance gains, and nothing too radical. When I first opened the wrapping, I immediately noticed certain flaws to it. Couple of minuscule gouges here and there. Nothing too bad. Still flaws regardless. I was expecting a nicer finish however. You can clearly see the machining it went through. I doubt this was intended. It does add a nice unintentional touch to them. I rate these a 8.5/10
It comes with two brackets and 4 Allen head bolts. The install is easy. Undo the four 12mm bolts, one bracket at a time. Take out the rubber mounts, pop them in the new bling, and secure it down with two of the four Allen head bolts. Use a 5mm hex key and tighten. Voila, the ricer in you screams with delight.
