Strange Noise
BlackStar
Feb 5, 2006
Colorado Springs, Colorado
:talon: Whats up yall, I own a 90 TSI AWD. When I drive it, I hear a loud ticking noise coming from the rear passenger side. I had the hub replaced a couple of months back and it has been doing it since about a week after that. Want to get it fixed because I am not sure if it is a safety hazard. Let me know. Thanx
I assume it increases with speed. Possibles: Backing plate bent and rubbing against rotor, or pad wear indicator rubbing, or bad cv joint, or wrong pads installed/misaligned, or wrong pad anti-rattle springs or anti-squeel plates installed/misaligned, or wheel bearing still bad (did you replace hub with a new or used one?), or lug nuts not tight. Does it go away when brakes are applied?
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
