stranded need some quick help please buzz noise from radio area
blackhawkgsx
250
Mar 6, 2010
Miami, Florida
hey guys i need some quick advice i was driving today turned off the car and when I attempt to turn it back on I just get a buzz noise from the radio area the starter does not crank over or anything . no fuses are blown thar i can see car has a new starter and battery . any ideas ?
I have narrowed the Buzz noise down to the I guess its the starter relay MB398020 and the MPI relay E8T08474 ... I tested the mpi relay pin 5 & 6 for resistance but nothing shouldn't I get 90 ohms? how can I test the starter relay ?
Brand new Ecu I check for any leaks/Burns and nothing...
For S's and G's, how do your battery connections look? Starter connections? Are they free from corrosion and tight/snug?
Not sure what they should read as far as resistance but they should click on when engaged so you should feel or hear it. You might do a search on here for mpi just make sure you highlight Titles only under all posts.
The ECU wouldn't matter with the starter turning over. It does with the MPI/Fuel relays, however. Have you checked your starter relay to see the sending voltage from it? check out the electrical user guide; if you don't have it, you can find it on Scribd.
So for now, don't worry about your MPI/Fuel relays or ECU. Just make sure that the starter relay is 'relaying' power to the starter. Also check the clutch safety switch (I believe this is a green wire with a black tracer) to the starter relay.
