2G Stop light fuse and cut wires
import47
5+ Year Contributor
40
7
Oct 6, 2020
San Antonio, Texas
Stop light 15 amp fuse keeps poppING. And im am clueless to electrical engineering but I have two cut wires in the audio line dont know what they connect to or attach yet one is black and the other is green
An open circuit will, typically, not cause a fuse to pop. What may be the issue is that something is chafed elsewhere and touching another circuit which will cause the fuse to go. If memory serves, San Antonio is not too humid, however, if where you got the car was fairly humid you may want to check the fuse boxes and make sure that you do not have corrosion in/on/around the area as it may be causing issues as well.
As I thought, I checked the wiring FSM and noticed that these two wires do not affect your brake light, however, it may take me a bit to locate these and isolate them. With that said, we can "assume" that black is ground of some sort, but the green could be anything. Does the stereo work at all or have any issues? Is your climate control lighting working okay? Check to make sure all the components in that area (turn signal flasher, MPI relay, radio, lighting) are all working correctly - my suspicion is that maybe your radio has an issue (if anything). But again, this may be a guess without doing some research.
Finally got the fuse to stop popping it was the door jam switch that was disconnected dont know why but the fuse didn't pop and the courtesy light and key reminder came on to
But the 2 wires on the audio loom still no clue
Looking at the FSM the two wires might be your cigarette lighter. Black is definitely a ground, the green and white will be the illumination - this is my guess. A way to check this is to check the voltage when the lights are turned on and connect to the ground, if you connect the two there should be a voltage between the two when the lights are turned on (parking or full).
i checked the FSM earlier and couldn't find a wire that was only green on any of the plugs there. I have a 95 harness that i can pull out to see what they go to. i'll try and get to it here in a little while.
here ya go, it goes to the ABS resistor (820 ohm, 1 watt, part # MB606742)
there was no ABS on the car the harness came out of but it has the resistor anyways.
*******edit******
i just noticed that the FSM says
B-14 resistor <with ABS or auto-cruise control system>
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
