Stock Turbo Help
project95talon
49
Jun 14, 2004
Sudbury,
Ok, as of lately my car boosts fine in first, once I hit second and third it never hits full boost until 5 ot 6 k, it feels alot slower also. I realize that the stock "boost" gauge is not actually measured acurratly, but may I have a boost leak of some sort? Or is is something else? I' m thinking about building the tester but I'm not sure if I should test without intalling an accurate boost gauge. Any help would be cool
95 tsi awd talon
You can check for leaks without having a boost gauge.
I would, however, get one as soon as possible.
PS Check it for leaks :thumb:
shit that was fast, thanks
So I'm just worried about pumping too much air , should I just use a regular bicycle pump instead of a air compressor.
I would think it would take to long when using a bike pump. Also, you probably wont hear the air rushing out if there was a leak and you used a bike pump.
You can set the air compressor to a max psi, say 25 psi and fill the system, if your worried about pumping to much air.
DaveT
92GSX
