Stock Temp Gauge Question
Thebeast431
151
Nov 23, 2002
deland, Florida
I currently don't have any logging software and just wondering what temperatures the stock water temp gauge is reading at the first hash mark? Half way point? And at the red line? My car currently runs near the 3/4 mark while driving on the highway for any length of time, just wondering if it's running warm or not. I was having a boiling over problem and trying to resolve it.
Also when I replaced the thermostat, I didn't remember where the bleeder valve, on the thermostat, was positioned in the housing . The Haynes manual said to make sure you position the thermostat back in the same position you found it in.
Thanks in advance,
Travis
1992 Talon Tsi AWD
1/4 line is like 150 half is like 200 and 3/4 is like 250 3/4is very hot should be in the middle
The gauge is not calibrated to degrees because it's not that accurate a sensor. It shows "cold", "fine", "hot", and "incinerated".
I just pulled a thermostat yesterday, the bleeder valve (a hole with a copper thing in it) was facing the top side of the housing, almost straight up. Hope that helps.
You say that the sensor is "not that inaccurate", does that mean the logger readings are not that reliable either?
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
