Stock injectors needing deadtime for idle tune?
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
I'm on stock 450cc blue top injectors, stock afpr and a 190lph walbro.
In order to get my combined fuel trip to +or- 2% for idle and cruising, I have to increase my dead time to 300. My air flow per rev is with in range from .25-.27 so my Maf adjustments are dead on.
Is it normal with an upgraded fuel pump to have to increase deadtime that much? Should I start reducing my global fuel % so my deadtimes aren't so high?
At what number should I be worried about having too much deadtime?
Thanks
BTW I love how user friendly Link is :hellyeah:
If its stock whats the problem, is it running funny? They shouldnt need a tune, someone correct me if im wrong.
Upgrading your fuel pump has nothing to do with injector deadtimes, but an increase in base fuel pressure will effect how fast the injector itself can open and close. A higher fuel pressure will increase the "deadtime" of the injectors.
So, if you've got a afpr on there running a 43.5psi base then yes, you'll need to increase deadtime for the stock injectors because the stock base fuel pressure for a 1g is 37psi. I see you mentioned that your running a stock 1g fpr but are you certain its a turbo 1g fpr? The N/T 1g fpr's look similar and bolt onto the turbo fuel rail however, base fuel pressure is bumped to 47psi base.
:dsm:
:dsm:
That makes sense, is there a way to check to see if it is indeed a N/T fpr? Looks like I'm going to get a afpr a lot sooner than expected.
Am I hurting the stock injectors or anything else running that much deadtime?
Thanks gofer.
Can you take a picture of the top of your stock fpr, I could tell you by looking at it if its the turbo or N/T 1g fpr.
You aren't hurting anything running a higher deadtime or higher base fuel pressure, I wouldn't be too worried about it to be honest. Just like on the Link forums though, posting a log can tell us A LOT more than what you post and describe. I wouldn't mind looking at an idle log you've got saved on your laptop with the car warmed up.
:dsm:
Well shit, if it takes you that long then just keep checking back here. I'll have a picture of each by tomorrow afternoon for you to check and verify which one you've got. LOL
:dsm:
That would work better because my weekend work schedule is hectic! I will try to get a quick log monday and post it.
I finally got around to taking pics of my stock FPR... based of the pics Gofer put up in another thread, it does seem like I have a N/T FPR.
check it out:
Damn. I knew there was another thread I was supposed to toss that picture in, that picture was actually taken for this thread, I just couldn't find it. :toobad:
Anyway, looking at your picture it appears, at least to me, that you've got a turbo fpr as it doesn't look like it's been "crushed" from the center.
:dsm:
:dsm:
haha..Thanks gofer. I knew you meant to put it in this thread too! Still confused on why I need my deadtime to be up so high with stock injectors.
Here is a quick idle log I did yesterday. Don't mind my ISC position not at 30 as it always wants to move +/-5 by itself.
Finally got around to verifying that I do have stock injectors. INP-009 by the connector, based off of my google search. It is in fact stock 1G injector (single spray pattern).
Comes down to having a 190lph, Fuel lab FPR set at 37 psi and stock Oem injectors but needing deadtime for idle tune. Only thing I haven't confirmed if it is infact a 190lph but after research it still wouldn't matter how big because of the fpr. Is this right?
Any other ideas? Wisemen?
Even on the ecmlink forums it's a baffle.
Thanks
