stock injector questions
yup. blue. they are also 450. oh, and the jdm motors dont have the usa auto trans cams. or the 390 injectors.
Even though it was shipped with a 13g? What are the specs on the jdm auto cams. Any info is extremely helpful.
MindBlowin03 said:
You may be right, but Ive seen JDM 4g63's with 13G turbos before. Not sure if that means anything.
i HAVE a jdm auto trans motor in my car. it came with a 13g, teeny exh manifold, blue top 450's, and M/T cams. i believe the markings are A and D. it was 3 years ago, i had the specs on the markings of the cams(A, B, C, D, i think, i have since tossed them) and i pulled the valve cover and checked, because i was going to install the M/T cams from the old motor. i also rechecked when i installed the hks 264's, and again when i switched them back. the cams will be STAMPED with the letter, on the end opposite the belt, and very, very tiny. but i found them. now, i have only seen 2 other jdm automatic trans motors, and both had the same as mine did. 450's, 13g, m/t cams. so maybe these were the only 3 in the world with that combo. 3 in a row is good enough for me.
