Stock gauge replacement
project1g
267
Nov 2, 2007
Jacksonville, North Carolina
I'm trying to upgrade the cosmetics of my 1g NT and figured I'd go ahead and replace all the stock gauges
I'm wondering where to find some replacements. All I've seen to come up with is EGT, boost, water temp, oil press., and tranny temp. Do they even make stock gauge replacements for cars that old?
Are you looking to add aftermarket gauges on say your A pillar or in the center console? Or are you talking about face overlays for the stock gauge cluster?
Aftermarket gauges to replace my tach and speedometer, fuel, oil, and temp. Would it even be a cool idea to put a gauge pod up and maybe run a water temp and oil pressure gauge? Or would that be making my car look like its suped up when it isn't? My main objective is to replace that stock look when night time hits I want people to be like !! those gauges are awesome !! That kind of thing.
Well, I don't know about replacing the speedometer, as I've never heard of anyone doing it.
I think it'd be best to get some gauge overlays for the stock cluster (you could either get the reverse glow or the blue/green ones). Then you could either do an A pillar (double or triple) with some gauges in it. And if you want even more, get a bezel to replace the vents in the center console. I'd say oil pressure, water temperature, air/fuel (if you wanted), or maybe others. Check out the 420A forums and see what they're running (the ones that don't have a turbo obviously). I would see it as a way to monitor your engine vitals, not having your car look 'sooped up'.
Well they had these gauges on Ebay but I've not had much luck with the things I buy from Ebay.
And all they did was glow blue or green. I like the idea of the pillar hooked up with some non problematic installation.
Thanks
:dsm:
project1g
