Stock converter with td05 20g
tsd123
135
Aug 9, 2006
Hickory, North Carolina
I've been searching for a bit but I can't find anyone running the td05 20g. I just need to know if I will be able to get into boost while foot breaking. I put an hx35 on it in a custom 7cm bolt on housing, but it doesn't spool early enough for the stock converter. I get about 2800 out of it before it stops. At maybe 1psi. I already have the 20g is why I was wondering. My engine is just a stock 6 bolt with Crower 272's.
You should be able to spool a 20g, good luck ever getting that hx35 to spool on a stock motor without nitrous. Our 2.3 stroker takes 7 seconds to spool an dbb FP black without nitrous, and our stall is 3100.
I realized I wouldn't be able to spool the hx35 fairly quick LOL. Changing the turbo is the cheapest option for me right now. Just really hoping it does spool with the 20g.
Oh really?
[ame=http://www.youtube.com/watch?v=4R8X6mxryfE]Stock converter hx35 auto launch - YouTube[/ame]
Peepers has run many 10.0x this year with his hx35 with the stock 6 bolt and stock converter. However, his setup is a little skewed due to his custom manifold he built with smaller runners than most use.
I know it takes about 5-7 seconds or so for him to get on the stall right now.
OP you should have no trouble stalling a 20g on a stock converter.
T4 TS on an 18cm housing and you can spool that on a stock converter? I am not that far in my build, but from what I've been looking at I got the impression that a stock converter on a 2.0 could not get an HX40 to build any decent boost decent on the line, with any manifold/turbine housing combo. This may change my build plans.
Thanks for the input guys. I have watched videos of peeper's car. I was wondering how he did it. Good to know.
A proper twin scroll setup like beans or peepers can do wonders on a 2.0 as long as you don't go overly aggressive with cam size or intake manifold systems. Anything tdo5 based turbo should be be able to spool up within 4-6 seconds depending on tune and supporting mods. Remember cam profile makes a big difference by shifting the powerband up or down.
