stock boost controller harness...
slow4G63
102
Jan 14, 2005
Huber Heights, Ohio
i just installed my dual stage boost controller and noticed that there is a wiring harness going to the stock boost controller. Can i disconnect the harness, tuck it somewhere in the engine compartment, then take the stock boost controller out? :confused:
thanks...
blackGSX2g said:
You can tuck it away anywhere you want as it is no longer being used. I believe you still need to have it plugged in or you will get a CEL.
what is a CEL?
CyberEye said:
Check Engine Light
ohhh, it already comes on when i hit fuel cut, then i have to reset the ecu :thumbdown ... that's because my exhaust (fuel cut)... i need to get a modded ecu or fuel injectors
I wouldn't be resetting your ECU all the time...I notice that when my ECU gets reset, I get bad gas mileage for about a tank of gas.
Oh and you shouldn't be hitting fuel cut with just an intake and exhaust.
you really should not have to be resetting your ECU unless you have to disconect the batt for something like a new mod or something. The ECU has a relearn process(hence the bad milage for a tank of gas or so) which adjusts your fuel map also causing you not to poerating at top performance. :laser:
