Stealth wheel and brake upgrade
autotalon
175
Dec 24, 2006
Vancouver, BC, Canada
I tried searching but couldn't find the info I was looking for.
I recently got a hold of a set of 94 TT stealth calipers, rotors, and wheels. I know about the caliper brackets, but can't find any info on people using the rotor. All I found is that people are using cobra rotors which are 13". The rotors from the stealth measure 12-3/8". Can I use them or is there a different bracket for them?
Also I can't seem to find a definite measurement of wheel spacer for the stealth wheels. The tires on them are 235/45/17.
I am also thinking of going back and getting the rear brakes from it as I have an automatic and losing the e-brake is not a big deal since the trans locks the car from moving. Just looking for opinions on that one.
Thanks.
It depends on the brackets you have. Please see my gallery.
I have early year stealth calipers. I have later year 3000gtvr4 rotors (powerslot). I am using stock 2g lines, nothing was changed. Bolted on with the bracket I purchased.
You must have enough offset in your wheels to clear the caliper. Stock Evo wheels work perfectly.
